Re: Re: Re: $350 Cub ..... Running
Posted by peterc on November 13, 2000 at 04:38:15 from (64.30.150.31):
In Reply to: Re: Re: $350 Cub ..... Running posted by Stan on November 12, 2000 at 10:05:22:
still could be a flow problem be sure all carb passages are clear also check carb mounting gasket and manifold gaskets for possible air leak that will give you a lean mixture making use of the choke necessary to keep it running
Post A Followup
: Re: Re: Re: Re: $350 Cub ..... Running
