Re: Putting a 350 egine Kit in a H engine
Posted by D Slater on March 26, 2013 at 06:41:34 from (184.15.9.188):
In Reply to: Putting a 350 egine Kit in a H engine posted by Greg Knapp on March 26, 2013 at 05:01:47:
Nominal block bore without sleeves. H block 3.562. 350 tractor block. 3.750. Original piston pin diameter H- 1.109. 350-.875. IH sold pistons for all with .875 pins and used adapter pin bushings in the rod. Aftermarket mostly sells big pins for H and SH and small for 300 and 350 piston and sleeve sets. Always a chance for a pin hole in the cylinder wall when boring the H block to 350 size. But H blocks are cheep. Counter bore in block needs changed also if using off the shelf sleeves.
Would look for a 300 or 350 block. May not cost any more than the machine work on a H block.
