Re: Hydraulic Hose Question
Posted by IH fan on March 26, 2013 at 08:11:41 from (108.246.53.173):
In Reply to: Hydraulic Hose Question posted by Global Warmer on March 25, 2013 at 18:38:26:
Global Warmer said: (quoted from post at 20:38:26 03/25/13) Hello all how is everyones projects going.
I"m debating on whether to use gates rubber hose or a stainless steel braided hose.
My second question is can I plug all the hydraulic pump inlets and outlets until I add hoses and still use the tractor.
Thanks to all reply"s in advance.
TMCKEE
Is this a series I or II Super H? If it has the series II timing gear driven pump, DO NOT plug the inlet and outlet pump ports. I don't know one way or the other about the belly pump on the earlier models, as I don't know the internal plumbing. You will break or burn up the timing gear driven pump on a series II, depending on how tight the intenal gears of the pump are. If they are somewhat loose, the oil left in the pump will slip by the gears and eventually get hot and burn up the pump. If the gears are tight, you will break something, probably one of the cam timing gears or the pump shaft or driving gear.
You could "loop" a hose from the inlet to the outlet and fill it with oil, but even that might tend to get hot if run a long time, bit it would be better than running it plugged.
This post was edited by IH fan at 08:15:26 03/26/13.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
