Re: loosen rusty bolts
Posted by Super H Mike on March 26, 2013 at 11:42:57 from (76.164.147.173):
In Reply to: loosen rusty bolts posted by Darwindo on March 26, 2013 at 08:23:45:
I just now mixed up a small batch of ATF and Acetone, and the mixture has seperated into its two parts in the jug after an hours time, so will need to be shook before each use, but I am gonna try it as a penetrant and see how it works. I have been using Deep Creep from Sea Foam or PB Blaster with good results.
