Re: F20 timing.
Posted by BruceS. on March 26, 2013 at 14:56:33 from (76.15.9.104):
In Reply to: F20 timing. posted by Andrew Psencik on March 26, 2013 at 14:02:52:
I use the flywheel D/C markings.Hopefully you can read them. Mag should trip just as D/c is going past the window (book says no farther than 8 degrees past window. Also, the crank pin on the pulley will be dead on horizontal. You can tell how close you're getting to D/C by watching the pin.
I adjust valves one cylinder at a time 1-3-4-2. Up to .020 cold is fine. If mag is in correct position and tripping at the right time, should fire right up.
