Re: F20 timing.
Posted by oldiron29 on March 26, 2013 at 16:24:25 from (74.88.11.200):
In Reply to: F20 timing. posted by Andrew Psencik on March 26, 2013 at 14:02:52:
Andrew, When you set the valves to .018 Did you get #1TDC #2TDC #3TDC #4TDC when you set the valves? Carb running lean will make if back fire
run rough and so on. What have you set? and is it correct? You need to stop chasing things around. Get the timming right and valves right and clean the carb again. Do you have a manual? oldiron29
