Posted by Kent V on March 26, 2013 at 16:56:32 from (75.198.84.96):
Problem: Hydraulics started to not work, i.e. power steering would pause, 3 point hitch would lift slowly and finally everything stopped.
New filter. Still doesn't work.
Disconnected suction tube and replaced with poly tubing connected to the suction side of the filter and placed the open end into a bucket of fluid. Sucks right up but still nothing works.
Disconnected high pressure line while suction is in bucket. Fluid is drawn up and pumped out just fine, maybe some air? But I can't stop the flow with my thumb so there is pressure.
Next step, put pressure gauge on high pressure output.
IF No pressure, or Low pressure I assume the pump is bad.
IF pressure will develop on the disconnected high pressure line, where do I look next.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
