Re: Change Super A Battery
Posted by athol carr on March 26, 2013 at 17:02:20 from (115.188.3.223):
In Reply to: Change Super A Battery posted by asyrp43 on March 26, 2013 at 06:52:08:
If it is an early Farmall Super A there is no separate side to the battery box, you have to undo the two bolts holding the battery box to the instrument cluster, undo the four bolts holding the battery box to the frame, remove the starter pull rod and the right-hand side touch-control rod, then holding the clutch pedal forward, slide the whole box out. Whoever designed that layout should have be dealt with at birth.
