Re: F20 timing.
Posted by Old-F20 on March 26, 2013 at 18:21:05 from (71.7.101.5):
In Reply to: F20 timing. posted by Andrew Psencik on March 26, 2013 at 17:07:58:
i meant the fuel priming cups. pull your valve cover off and make sure the hollow tubes are plugged off. if not it'll act lean and not run worth a crap
i know, i did this once
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
