Re: Farmall 706D
Posted by AG in IN on March 26, 2013 at 18:46:57 from (67.237.17.251):
In Reply to: Farmall 706D posted by Michael Allen on March 26, 2013 at 17:15:26:
If you're asking what size moldboard plow should you use, this question gets asked at least once a week about a tractor model and there's no real agreement on plow size for any tractor, because personal experiences on plow size for a particular model of tractor vary.
If you have heavy ground and/or want to plow deep, you're likely looking at a 3-plow tractor. Packed ground and pasture/hay ground pulls hard, too.
If you want to plow beach sand 4 inches deep, it likely will pull 6-16 or even a larger plow.
Anything in between is possible somewhere depending on soil types, hills, plowing depth, plowing speed, tires, proper weighting, proper draft, tractor/engine condition, plow bottom types, etc.. How hard you want to work the tractor comes into play, too. If you want a buster bar, harrow, or packer behind the plow, that will cost horsepower and may narrow the plow some, too.
FWIW, 4-14 is likely as much as it would pull here, but you'd be working the snot out of that engine much of the time, which I would say is something you should do at your own risk with a 50 year old D-282. TA would get a fair amount of use with 4-14 on a 706 here, too.
The fast hitch field cultivator may be a Model 45 or a similar machine. If so, it's not a fancy machine, not a bad machine, and not a high-dollar machine today in any of it's incarnations, either. Vibra-shanks are good if the springs aren't wore out or sprung. Shank pivot can wear out, too. Shank parts should still be available, and a variety of sweeps/shovels/points are available from CIH and from aftermarket suppliers.
AG
This post was edited by AG in IN at 19:04:54 03/26/13 2 times.
