Hi Well Worn, thank you for your reply. I think what you are referring to with the spring and ball is the pressure regulator valve. I am having trouble with the safety valve which is directly above the pressure regulator valve. The safety valve has a spring that is 1&15/16" long that sits in a cup (safety valve sleeve) and then behind that is the safety valve piston. That safety valve piston won't slide out of it's bore which is a much smaller diam. bore than the sleeve sits in. That sleeve backs up against a plug with about 1/8" diam. hole in the middle that I can look thru and see the piston, but the hole isn't large enough to get the piston through. My thought is that plug must come out somehow, but how? Case sells the piston so I know it must come out. Any continued help from you or any readers would be appreciated!
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
