Re: Farmall 140 help
Posted by Erik Dekeyser on March 27, 2013 at 17:15:31 from (184.151.61.195):
In Reply to: Farmall 140 help posted by Farmall4life on March 27, 2013 at 15:06:44:
Did you try to disconect the fuel line at the caburator to see if you have a good flow of fuel. You might have cleaned the bowl out but at the top of the bowl the part that goes into the tank there isnt a nice opening it has a little peice of steel up there that stops bigger peices of dirt and rust from getting into the bowl. So if there is some rust in the tank it will slow down the fuel going into the bowl. Also there is a filter in the fuel line at the carb right in the elbo. I hope this helps you.. Erik.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
