Posted by IHSMOKE on March 27, 2013 at 20:42:08 from (98.74.186.231):
In Reply to: Farmall 140 help posted by Farmall4life on March 27, 2013 at 15:06:44:
do you have the float set way to low and cutting the fuel off with out enough fuel in the carb. bowl to speed up /// think of it as running out of gas cause there is not enough in the bowl to allow for a faster engine speed .. faster engine speed draws the gas out of the fuel bowl faster then it flows back in cause the float cuts it off early ..problem is that ya set the float lower to stop flooding and then u starve the engine for fuel ....CLEAR AS MUD RIGHT ?? IHSMOKE
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
Latest Ad:
[More Ads]
