Re: F-12 F-14 Heads
Posted by athol carr on March 28, 2013 at 12:58:21 from (115.188.3.223):
In Reply to: F-12 F-14 Heads posted by Dave S. on March 28, 2013 at 05:31:42:
As far as I know the heads are all the same, the difference was in the pistons, seemed as if the gudgeon pin was further up the pistons so that the swept volume was the same but the piston did not get as close to the top of the cylinder. Even with that, the compression ratio of the gasoline tractors was only about 4.4 to 1, similar to the compression ratio on the later letter series tractors for kerosene and distillate engines.
