Re: international wont fire
Posted by DoubleR on March 29, 2013 at 05:53:09 from (198.105.230.174):
In Reply to: international wont fire posted by sheperd on March 28, 2013 at 18:40:41:
I have had the spring on the points break and the tractor just quit on me. Might be something to check. Although since it was coughing and sputtering first that doesn't sound like the problem.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
