Have your shop manual ready and do it, probably the easiest pump change you will ever do. I don't bother finding number one, just line up the marks, set the pointer on the flywheel and go, if it's out 180 degrees and won't start when you are done it only takes about two minutes to turn the pump to where it is right and you're done.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
