Re: Stripped threads on carb
Posted by mkirsch on March 30, 2013 at 06:32:01 from (67.253.161.186):
In Reply to: Stripped threads on carb posted by 7lazy77 on March 29, 2013 at 23:02:42:
Well now, what is stripped?
IH carbs generally have studs and nuts to hold them to the manifold.
Is the stud stripped? Is the carb body itself stripped?
IF it's just the stud you can replace it easy enough.
IF the carb body is stripped, depending on the tractor you might be able to just run a bolt in from the top and put a nut on the bottom.
