Re: Hydraulic pump seals 350 Diesel
Posted by D Slater on March 30, 2013 at 17:19:06 from (184.15.9.188):
In Reply to: Re: Hydraulic pump seals 350 Diesel posted by David Bowers on March 29, 2013 at 11:15:45:
From memory that's a special end that can't be serviced if its leaking between the nut with male pipe threads and the steel pipe.
Can't remember how straight the pipe is near the nut. You can get a compression fitting to fit on the steel pipe (need to cut pipe) with pipe threads on the other end from a hydraulic shop that can work. May need to install it on the pipe and use a short pipe to make it fit. Unless the pipe is straight just right behind the nut the fitting may reach. See about half or more of those tractors or more with a hydraulic hose replacing the line from the pump to the block.
