Re: Farmall 706 gas crank seals
Posted by P T Farmer on March 31, 2013 at 18:39:38 from (71.7.253.132):
In Reply to: Farmall 706 gas crank seals posted by P T Farmer on March 31, 2013 at 16:40:49:
Hi again and thanks for the replies. The worst thing is that I just put the tractor back together after having it split. I had oil leaking, hydraulic oil, and found the ipto shaft seal was damaged. So I replaced the seals, cleaned everything and put her back together. Now the oil leaking is much less and darker, engine oil, but still leaking. I guess I focused too much on the hydraulic issue. I put about 16 hours on it spreading manure over this weekend and its wet and dripping around the back of the oilpan and through the inspection hole under the clutch. I can live with it for now but I"m still wondering about the crank seals.
Thanks.
