Re: 560 Stuck engine
Posted by Bob And on March 31, 2013 at 18:48:34 from (75.238.195.109):
In Reply to: 560 Stuck engine posted by Bob And on March 26, 2013 at 18:44:05:
lots of good information here. I put in a mixture of ATF and enamel thinner in each cylinder, let it set for an afternoon, jacked up the left rear wheel, put it in 5th gear and started rocking the wheel back and forth. It took about ten cycles and finally I saw the fan blades starting to move. Put in the battery, hit the starter and it was free.
So it wasn't stuck all that bad.
Thanks guys and hope maybe this will help someone else sometime.
