Re: 706 trouble
Posted by DeltaRed on April 01, 2013 at 07:01:33 from (71.208.220.227):
In Reply to: 706 trouble posted by BillyH71 on April 01, 2013 at 06:37:39:
I would first remove the cowling over the instruments and check the shift linkages.Thhen I would pull the range cover(under the platform).If you havr e reverse and steering and the pto works,the clutch is ok.There is a 'plate'down by the clutch pedal to removeto see the reverse shihter fork.I would do these things before a split....My feeling is something in the range shifter is your problem.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
