Re: 706 trouble
Posted by Jim Naden on April 01, 2013 at 10:04:16 from (63.151.142.198):
In Reply to: 706 trouble posted by BillyH71 on April 01, 2013 at 09:52:08:
The shift rail is in the range transmission compartment.
You'll need to remove the range cover to access.
Or you could remove the accessary drive cover on the left side of rear frame for quick inspection.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
