Re: IH 574 PTO won't turn off
Posted by Yatesonfire on April 01, 2013 at 20:31:13 from (184.19.216.254):
In Reply to: Re: IH 574 PTO won't turn off posted by jimb2 on April 01, 2013 at 20:06:13:
Jimb thanks for the reply. I have checked all adjustments clear the debris lubed the lever and have replaced the PTO clutches, also the hydraulic oil and filter. Still no luck the PTO will not shut off while the engine is running. I guess the PTO valve in the MCV is next ??
