Sounds like clutch pack has slipped and welded up ???
Easy check, go to MCV (where filter is) and at the rear of the MCV there is a small pipe that goes from the MCV rearwards into the tranny casing, this is the pto oil supply. Remove the pipe from the MCV and put a cap on the MCV fitting.
If pto stops it is an oil supply issue and the ipto spool and linkage in MCV need adjusting.
If it continues rotating, the clutch pack has welded up and needs an overhaul!!
Shop time to test and overhaul is around 2 1/2 hours!!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
