Posted by Owen Aaland on April 02, 2013 at 00:35:30 from (216.47.35.128):
In Reply to: Tractor Repair posted by Frank Castro on April 01, 2013 at 18:35:36:
You should have voltage on the distributor side of the coil with the points open and no voltage with the points closed. Check for a short to ground in the wire from the coil to the distributor. probably shorted where the terminal bolt goes through the distributor housing.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
