Re: Tractor Repair
Posted by nebraska cowman on April 02, 2013 at 04:21:02 from (166.182.3.98):
In Reply to: Re: Tractor Repair posted by Frank Castro on April 01, 2013 at 18:35:36:
No power is supposed to go to the distributor. The distributor grounds the coil to build the spark. When the points break the spark jumps. The distributor runs the coil, not the other way around.
