Re: 560 misses
Posted by d282 on April 03, 2013 at 04:59:09 from (209.152.94.237):
In Reply to: 560 misses posted by Darald on April 02, 2013 at 20:31:09:
If it has power when pulling but does the white smoke thing at wide open with steady load it could be the pump shaft seals.
