Re: 560 misses
Posted by Janicholson on April 03, 2013 at 06:29:34 from (199.17.6.34):
In Reply to: 560 misses posted by Darald on April 02, 2013 at 20:31:09:
If the puffs are evenly spaced and not random, I suspect the injector (probably one or more) they act differently when idling than when putting out max fuel. Use a pyrometer on the exhaust (or crack the fitting open on each injector to locate the misfire) and then swap injectors between holes to see if it follows the injector. If so it is the injector. if not it could be low compression on that cylinder. Jim
