Posted by caseman-d on April 03, 2013 at 07:30:56 from (67.142.174.22):
In Reply to: 450 froze posted by chris450 on April 02, 2013 at 13:23:31:
WOW,Sounds like you must of had the exhaust wide open to get that much moisture in. Since it's water you're better off than if it was antifreeze. Take a heat lamp or shop light and shine it close to the oil pan. Pull the drain plug and let the oil dry. You will be surprised how well that heat lamp will warm the pan and melt the ice. Once that is done change oil and filter, run, check and see if oil turns milky you will want to change again. No oil pressure could mean you ice block in line. You must be a lucky one to have that much moisture in your area. caseman-d
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
