B414 Hydraulic filter
Posted by Phil Tibbetts on April 03, 2013 at 07:43:22 from (208.93.14.38):
I am trying to fix up a B414 and found that the hydraulic filter screen is gone. the tube and fitting with o-ring is there but the screen is completely gone. Any one know where I can get a used one?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
