Posted by wayne in mn on April 03, 2013 at 10:50:21 from (64.118.12.213):
In Reply to: pto for m posted by pheel on April 03, 2013 at 10:40:15:
Not difficult at all; either drain some of the transmission oil, put a 5 gallon bucket underneath, or put the front tires in a hole because the oil level is higher than the PTO opening. Remove the capscrews attaching the unit and pull it out; may have to pry a bit. You have to "steer" the driveshaft when re-assembling so a 2' piece of pipe over the splined shaft will help direct things back together.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
