Re: 560 misses
Posted by Dieseltech on April 03, 2013 at 11:39:47 from (98.206.80.148):
In Reply to: 560 misses posted by Darald on April 02, 2013 at 20:31:09:
Second what pete said, the light load advance may not be working correctly. With full load should be full retard, half load 2 degrees advance, no load lo or high idle full 4 degrees advance. Best to set on either a test stand or PTO dyno with the batwing gauge. Engine will sound like it is missing if timing stays retarded at no or lite load.
