Re: 450 froze
Posted by SDE on April 03, 2013 at 14:14:23 from (174.124.45.124):
In Reply to: 450 froze posted by chris450 on April 02, 2013 at 13:23:31:
When you are ready to put the oil back in it, heat the oil first, and then let it sit for a while. Just in case you still have some ice in the pump screen. You definitely do not want to start it again without oil pressure. Maybe you should pull the spark plugs out and pull the tractor, to see if you have oil pressure before you try to run it.
SDE
