Farmall 400 hydraulics
Posted by T.R. Dickinson on April 03, 2013 at 18:32:38 from (173.86.93.227):
How do you bleed the hydraulics on a Farmall 400 Gas. The pump hummes and whine wjen idling, when I work the hydraulic controls and put it under unload it stops making the noises. Thanks for any help.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
