Re: Replacing Transmission Seal on Farmall B
Posted by Daniel H. on April 04, 2013 at 09:45:18 from (66.226.61.106):
In Reply to: Replacing Transmission Seal on Farmall B posted by jkmdg84 on April 04, 2013 at 08:51:25:
You should not need a retainer or shims just the seal. The retainer does not need to come out. You should replace the seal in both the transmission and also in the drop housing. The shaft may need some clean up at a machine shop, if it is grooved the new seals won't hold.
