Re: 1206 Torque Repair
Posted by caseyc on April 05, 2013 at 06:17:21 from (75.102.189.131):
In Reply to: 1206 Torque Repair posted by larryanderson on April 05, 2013 at 05:00:43:
The only proper repair is a new T/A. There is no fixing a slightly slipping one unless the linkage isn't quit right. Find a service manual and follow the directions for adjustment to a T. I believe the clutch needs to be adjusted first, again to factory specs. As far as cost a new T/A is in the $1200 range and i'm not sure on labor. You should probably consider a clutch too while your already in there. Just my opinion.
Casey in SD
