Re: 3pt Quick Hitch on a Saginaw?
Posted by Phil Tibbetts on April 05, 2013 at 10:07:08 from (208.93.14.38):
In Reply to: 3pt Quick Hitch on a Saginaw? posted by Yooper Farmall on April 05, 2013 at 07:53:55:
I have a quick hitch and use it for some implements but it requires a set of special bushings for each one unless you want to keep changing them. Also they are quite expensive if you buy a set for each implement. Probably would not throw $200 bucks for another. IMO
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
