Yes the shaft will slide out of the transmission as you separate the drop housing (final drive) from the transmission. It is heavy- be sure you have the hoist attached securely. Once you separate it, remove the cover over the bearing and remove the set screw from the brake drum and bump the shaft out through the drum and the final using a big hammer and a block of wood. The bearing will come out with the shaft.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
