Posted by Bob M on April 06, 2013 at 12:55:44 from (67.240.171.136):
In Reply to: Stumped posted by Dan Richardson on April 06, 2013 at 10:18:30:
Dan - If running at partial choke stops the loping, problem is a chronic lean condition. A few common causes:
- leak at the carb to manifold flange - leak at the manifold to head gasket - a plugged carburetor port - especially the idle port in the carb throat by just above the throttle plate - float level set too low - broken idle mixture screw (note turning the screw IN makes the mixture richer) - improperly assembled carburetor
Also do as Bouncer suggests: Check for good fuel flow into the carburetor. Remove the drain plug or cock from the bottom of the bowl - it should flow a solid stream of gas. If gas just dribbles out there's a restriction)
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
