Re: Farmall 300 gas leak
Posted by gene bender on April 06, 2013 at 13:31:19 from (67.55.226.151):
In Reply to: Farmall 300 gas leak posted by Evan Mellott from Iowa on April 06, 2013 at 13:17:05:
There is packing on the shut-off valve just tighten the nut a little it will then make the valve turn a little harder. Put the rubber in the top part then the screen and it will not leak at the glass bowl.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
