Posted by Bob M on April 06, 2013 at 13:58:14 from (67.240.171.136):
In Reply to: Farmall 300 gas leak posted by Evan Mellott from Iowa on April 06, 2013 at 13:17:05:
Sounds like there's 2 problems here:
1 - Fuel dripping from the carb and from the sediment bulb shutoff handle says the sediment bulb is worn out. Replacing with complete new bulb assembly will cure that.
2 - Fuel coming from the bottom of the carb and between the bowl and air horn castings means the float needle valve is not shutting off when the bowl is full. Could be junk caught in the needle valve, a worn out needle, float level set to high, or a rubbing or gas-logged float. And gas leaking around the carb gasket means either the screws that hold the two halves together are loose, the gasket is bad, or (unlikely) there's a crack in the upper part of the bowl casting.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
[More Ads]
