Re: W4 starter removal
Posted by John M on April 06, 2013 at 17:43:45 from (209.213.28.157):
In Reply to: Re: W4 starter removal posted by charlespretzer on April 06, 2013 at 12:38:13:
Remove as many of the clutch cover bols as you can.I think one or 2 will not come all the way out, but get them as far as they will go. Then pry up gently on the side where the starter is, right up under the starter and at the same time lift up on the rear of the starter and pull out at the same time. You dont have to remove the belt pulley this way.
