Re: farmall m belly pump ?
Posted by rocklong on April 07, 2013 at 05:53:41 from (184.21.23.110):
In Reply to: farmall m belly pump ? posted by rocklong on April 05, 2013 at 20:19:27:
I guess the seals r cheap I will just pull it stop the leak and look for major problems. Then put it back in and try it if it don't work I'm not out much. I was also wandering about the control lever. Should I spring forward on it own. There is no controll rod on mine just the lever. When I reinstall the lever is there a certain way it has to go in, it feels spring loaded.
