Re: farmall m belly pump ?
Posted by rocklong on April 07, 2013 at 16:47:20 from (184.21.23.110):
In Reply to: farmall m belly pump ? posted by rocklong on April 05, 2013 at 20:19:27:
The pump seems to work on just a cylinder with no weight. I think I am going to get a three point to move hay bales. So if I come out the right side port into a 4 way open spool double action valve then out of valve and return to drain port on tractor and hook up the cylinders I should have power up and down right. Is that the kind of valve I need.
