A transmission
Posted by cheif on April 08, 2013 at 06:43:26 from (69.131.182.172):
My "project" Farmall A has a rattly squeally noise when idling in nuetral. I removed the cover and found the oiler gear was mostly missing. I can find no worn gears or bearings to cause the noise so before I disassemble the transmission to replace the oiler I would like to find the source of the noise.
The only gear driven in nuetral is the reverse idler. Have any of you farmall mechs had that problem?
