Posted by Scott Blanchard on April 08, 2013 at 14:38:30 from (64.222.97.189):
I looked all through the internet to find out the procedure to tune my valves after a motor job on my Super C. It made is sound like I could rotate my front piston to TDC on the compression stoke, then .014 clearance on both valves of the 1 and 3 piston. Then rotate to the compression stroke of #2 and adjust all valves of 2 and 4. When I did this the exhaust valve of both 3 and four seemed way off. (I turned it over a few times by hand.) I went back and adjusted them back on each individual cylinder's compression stroke. It starts and sounds right but i am worried I'm going to burn a valve. Am I way off? Thanks in advance
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
