Try to use nothing larger than a 37 amp "1wire" Delco alternator. A 61 or 72 amp"1 wire" alternator needs nearly twice as much rpm to self excite. Use as small a pulley on the alternator as you can find to run it as fast as possible. I find that it is much easier to adjust the alternator belt when I build the alternator bracket with slotted holes 2 inches long where it bolts to the engine. This allows moving the alternator up / down as well as sideways to tighten the belt. I also like the link type belts from a bearings and drives shop, that can be installed without removing the fan belt, plus the length can be adjusted so easily by just adding / removing links until it is right.
If Your "1 wire " alternator needs more RPM to excite than your comfortable with, nothing is lost, just buy a regulator plug and charge light to wire it up as a "stock 3 wire" alternator. The "1 wire" unit will work just fine when wired as a 3 wire and will excite at lower rpm, just like a normal 3 wire unit.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
