Re: Farmall H 1st gear noise
Posted by Janicholson on April 08, 2013 at 15:59:17 from (74.60.94.18):
In Reply to: Re: Farmall H 1st gear noise posted by Mark Carey on April 08, 2013 at 15:43:53:
The detent ball and spring in the first/reverse slot (and possibly others) may have rusted weak or broken. The balls of the detent may also be rusted stuck in the little bores they move in.
If the belt pulley gear is meshed too deeply into the drive gear, it can make radical noise. It is shimmed using gasket thickness. The shifter lever pivot pin and tip geometry might need tightening up, Pin wear is very common. Jim
