1 - Belt length it depends how your alternator is attached. Suggest you mount the alternator, cut an an old A- or 4L-section (1/2" wide) belt, wrap it around both pulleys, mark where the belt overlaps, then measure the actual length required.
2 - For a Delco on an H I recommend a solid mount. Arrange it so the alternator is JUST (1/8") clear of the rockerbox - otherwise the hood won't fit over. Then use an adjustable idler to set the belt tension.
3 - The old stock ammeter will work fine. It'll peg on the charge side after your first start the engine but it won't harm the ammeter. (My Super M's been pegging its original ammeter for 35+ years - it still works perfectly!)
4 - A coil marked "w/o series resistance" requires no ballast resistor. You should be wired direct to the ignition switch.
Tip: Use the SMALLEST pulley possible on the alternator! Otherwise the 1-wire alternator may not spin up fast enough to cause the regulator to "turn on" at startup.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
