Re: H and 300 wheel bearing swap?
Posted by rhtx55 on April 08, 2013 at 17:46:00 from (68.185.207.25):
In Reply to: H and 300 wheel bearing swap? posted by Zachary Hoyt on April 06, 2013 at 19:27:08:
Call your IH dealer & give him the number stamped on your wheel hub.
There were two different part numbers of wheel hubs used on both tractors.
If the number on the H wheel hub matches the one on the 300 you are good to go.
The wheel hub number will dictate which wheel bearings or kit you use.
